Community Member
Questions with CiscoRVS4000
We bought 2 CiscoRVS4000 for our branch offices and they work great. I have the following Questions:
1. is there a CLI to the box?
2. What is the latest published firmare?
3. I found a bug int the software. See attached image. Remote managment is enabled but wont allow me to disable it. Same with the HTTPS port. I cant seem to make it not allow remote management. Any solution?
4. I am runinng STAR 9202 CPU and V1.3.1.0 firmware.
Please let me know.
Thanks!
Community Member
Re: Questions with CiscoRVS4000
I can't help you with much of it unfortunately!
You are running the latest published firmware according to the Cisco site.
Are they creating a VPN connection between them? That might explain why you can't disable some of the features.
Cheers
Community Member
not speaking officially, it appears you have the latest firmware and that CLI is not supported.
hopefully more firmware is coming as there are still quite a few open issues.
nrf
Community Member
It might be effective to access the RVS4000 interface with a different browser.
Instead of Interent Explorer, try changing settings with Firefox. The RVS4000
has intermittent issues when accessed via Internet Explorer - changing settings
and saving the changes reliably, upgrading signature file, etc. all work better
using Firefox.
I have no idea if this is the cause of the remote access snafu but as a general
rule forget about operating the RVS4000 with IE - Firefox works much better.
660
