Community Member
QuickVPN client login issues
I am using a RV180W router and using QuickVPN client ver 1.4.2.1  for remote access. Both the client and server are Window7.
I have create 4 users in the router. I can connect using one user logon but when I logout and try to connect with a different user it fails to connect.
Some times to user that initially connects will fail the next time a connection is tried.
Any ideas>>>>>
Richard
1 REPLY
Hello Richard,
Can you share what is noted in the logs of QuickVPN for the failed connection. You will find the log.txt file in Quick VPN folder.
Kremena
185
