QuickVPN hangs on Verifying Network
I have an RVS4400. I went into the VPN tab and then the VPN Client Accounts tab. I entered the desired username and password, then clicked Add/Save button. I click the Active box and click Save Settings button.
I now configure QuickVPN client with the profile name, username and password that I created on the router, the public IP of my VPN router, and have the port set for 443. When I connect, it goes through fine until it hangs at verifying network. It eventually times out.
From within the LAN, I can connect just fine. I've even disabled the Firewall on the router.
Please help. Thanks.
Manny
1 REPLY
Re: QuickVPN hangs on Verifying Network
There is a NAT-T problem with Windows XP SP2 and there is a registry change that must be made.
http://support.microsoft.com/kb/885407
Windows Vista you need to turn the Windows firewall on for IPSEC connections to be made.
http://support.microsoft.com/kb/926179
I  tried these on my Vista and XP machines and finally got a connection to my WRVS4400N.
Both 32 bit may work for 64 bit but my 64 bit XP machine is inside my firewall.
Message was edited by: Chris Mueller
2321
