Hi Bob, the QuickVPN relies on you using a different subnet when connecting as an external client. So if your router is configured 192.168.1.x then your client connection LAN should be anything BUT 192.168.1.x subnet.
Upon connection, the router populates a route table to allow the communication. Since the router is not assigning you an IP (virtual adapter connection) there may be other caveat with whatever you're trying to access. To simplify things the most, especially for testing, I'd recommend to disable any security suites or firewalls to achieve your basic connectivity then modify those other services to address any issues.
-Tom
Please mark answered for helpful posts
-Tom
http://blogs.cisco.com/smallbusiness/
