Regarding rv130w router
Dear Mr/Mrs,
I bought cisco rv130w wifi vpn router in HK, my question is 1. Must it use DNS to connect WAN? 2. Does the wifi also need to put DNS server for internet?
Best Regards,
Kenneth
1 REPLY
VIP Purple
If it is the only device that
If it is the only device that you have setup it should use DNS as DNS resolves ip address to name for internet use , you need this somewhere on your network whether this device or another
If your wireless and wired are on different vlans with different dhcp pools then yes , each dhcp pool needs DNS but if all 1 pool just apply it to that
63
