New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
Remote alterations
I'm in Australia and presently look after 6 x SRP 527 W Routers that are connected to Alcatel PABX phone systems. When I need to alter things like static ip addresses for vpn's I have presently have to go to site and alter these setting. I can log in remotely to these routers but every time I make a change the router gives me the message The values are invalid. I enter the same value from on site and it works. What do I have to do to get this to work and can I make the change remotely or will I have to go to site to make these changes?
Please help.
Also are there courses that I can do to learn more about these routers?
1 REPLY
Bronze
Remote alterations
Dear Mark,
Thank you for reaching the Small Business Support Community.
Since the same configuration parameter works on one SRP527 but not another, I believe this has something to do with the firmware release version and therefore I suggest you to make sure run the latest one,
http://software.cisco.com/download/release.html?mdfid=282910822&flowid=797&softwareid=282919993&release=1.01.19&relind=AVAILABLE&rellifecycle=&reltype=latest
Data sheets and literature for SRP500 series;
http://www.cisco.com/en/US/products/ps10500/prod_literature.html
Admin guide (with firmware upgrade details on chapter 8);
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/administration/srp500_admin.pdf
If remote access is already enabled then you can do the upgrade remotely;
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=fd998d22d7804f73a717e77ff89f729d_Configure_Remote_Access_through_Web_Access_Management_on_SRP.xml&pid=2&converted=0
Pretty much this admin guide is all we know about this routers, please check it out and let me know if you have any question and/or if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
442
