Remote Desktop and Cisco RV042 Small Business
With our old Linksys wireless router on Applications issue we can redirect port, for example:
Remote Desktop access from external pc: 201.85.X.X:1234    (appoint to our public IP and port 1234 )
Whit this we access in the Lan the private 10.1.X.X  WinVista Pro machine terminal services.
I want to forward port  1234  external >>>  3389 Lan . Is possible with RV042 ??
Note: Firmware Version :     v4.1.1.01 (the most recent)
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
To change ports source/destination you need to use the UPnP feature
that's what i use on the RV0XX
best luck
The asymmetric port forwarding config table is available at the Setup>UPnP page. Note that UPnP needs not be enabled (i.e. the UPnP checkbox can remain unchecked) to use the asymmetric port forwarding.
best luck
Re: Remote Desktop and Cisco RV042 Small Business
Nice, I'll try UPnp later. Thanks.
Done, works great. Thanks a lot.
1999
