11-13-2012 12:29 AM
I have been sold a rvs4000 but I think it will not do what I want it to some help would be very appreciated.
This my setup fibre broadband with a router with LAN ports only, no WAN port.
2media streamers to go through the router via VPN back to the uk
Can this be done as my broadband router has no wan port.
Many thanks for any help
11-18-2012 01:32 AM
In regards to the RVS4000 you will need a public WAN IP to complete a site to site VPN.
Thank you,
Jason Nickle
11-19-2012 08:28 PM
MArk...
I have come accross the same issue in the last week., Its been fixed...
Solution I : Get additional Public IP from ISP. Then do the static configuration on RVS4000 WAN Port Vs ISP router/Modem LAN port.
Solution II : Assign Different Subnet address to these ports.. then play with NAT rule on the ISP Modem/Router.
regards,
ssp
