Router for small business Internet connection
One of our clients recently switched ISPs to Speakeasy who installed a Hatteras HN 407 bridge. We have had Internet connectivity problems using their SonicWall 3060 firewall, and we experienced similar problems when attempting to use a newer Sonicwall TZ180. We temporarily installed a Linksys W54GT router, which has been working perfectly; however, we would like to have a more robust router for their 25 user network - additional security options, performance, VPN, two WAN connections, etc. Can you recommend a small business router with 2 WAN connections? This customer has a business ethernet 3Mbps (up and down) Internet connection, uses an online medical scheduling program, normally has 10 - 20 uses using the Internet connection and will be installing a backup DSL line that we would like to use for load balancing.
  • Small Business Routers
1 REPLY
Re: Router for small business Internet connection
Our recommendation for Dual WAN would be RV082 This would be the prefect VPN router for small  Business and if you are looking for more ports on  the Ethernet, then we would recommend the RV016
2116
