12-21-2011 08:24 PM
Hi Folks!
Since my last question regarding wireless routers was so easily answered I thought I'd give this another shot!
The Problem: I'm running out of IP addresses on my network (class C address)
The Evil Plan: Add a second subnet to my DHCP server, make the new subnet my DHCP pool and route between the two subnets (that way I'll increase my IP address pool and not have to touch my existing fixed IP systems. It also gives me a "network management subnet" and a "client subnet".)
I'm having a little trouble picking out a router however. I don't really need a whole bunch of bells and whistles for this project.
Anyone have any suggestions?
Many Thanks!
-B
12-22-2011 01:25 PM
Brett,
Since you are running out of address on a CLASS C then I would recommend this router.
SA520, SA520W, SA540
Overview
Also if you would like to consult with an engineer and give more information about your network, we could suggest a different router depending on your network topology. The SA500 model is at the top of the Cisco Small Business devices.
Cisco Small Business Support Center 1-866-606-1866
Hope this helps,
Jasbryan
12-22-2011 10:34 PM
Brett,
Your "Evil Plan" is actually not a bad idea. Why not use the RV220W for this? You can still use the wireless access point and create multiple subnets and SSIDs to expand your IP pool.
12-23-2011 10:32 AM
Good suggestion! I will certainly look into it. Sure would be nice to get this project completed with the equipment I already have.
We're only about 100 people now, but quicly growing. I'll need to research to see if the RV220W can handle the traffic (which may be my ignorance kicking in as I'm still learning the ins and outs of routing.)
Thank you for the suggestion!
