router srp 527w logging capabilities
I have bought recently srp 527w router. I am using it with very simple network configuration at the moment, containing 2 laptops connected via ethernet ports on the same VLAN and ADSL connection. All is working fine except that I am unable to find proper logs. If I log in as admin user I can see Log page and there I can see some logs of the router but not the logs of the firewall. I would like to see blocked incoming connections for example.
I am also unable to find syslog support for logs. I would like to send firewall logs to my external syslog server. It would be hard to believe that this basic functionality is not available in cisco router. My 5 year old netgear router has this implemented.
Any help would be much appreciated. Otherwise I would be forced to send the router back.
A.
Re: router srp 527w logging capabilities
It is possible to generate syslog messages from the SRP - although currently it's a little unusual for the SRP520.  To enable, go to Voice > System, enter your syslog server IP and select the "3+Router" level to generate router messages.
The new SRP540 has this functionality available in the admin logs section.  It also has a dedicated Firewall log too.
Andy
Hi,I have enabled SYSLOG as
I have enabled SYSLOG as per your instructions and can see the log entries on my SYSLOG server, however I want to see all port 80 (HTTP) and 5060 (SIP) requests coming into the router from external so that I can see the IP addresses of the requestors. How do I configure the SRP527W to show this additional log information in SYSLOG?
John
686
