Routing between two VPN Tunnels in Cisco RV042G WAN VPN Router
We are planning to move some services in cloud. Due to our supplier already has a VPN connection with that cloud service provider, its not possible to have another VPN with them (cloud SP limitations). For this reason, we are planning to have a intermediate device, that will act as a bridge between the two VPNS.
So our device will be sitting in the middle, terminate two VPN (cloud--us and us-supplier), and route traffic through two tunnels.
Is it technically possible to achieve this scenario? we are planning this device Cisco RV042G Dual Gigabit WAN VPN Router. Will ASA 5520 be a better solution for this? or any other suggestion?
Thanks in advance
Ahmed
  • Small Business Routers
Everyone's tags (1)
rv042g will do 2 vpns, but
rv042g will do 2 vpns, but wiil not route traffic from one to the other.
The ipsec SAs will not have the interesting traffic from the other tunnel.
You are correct the ASA might be a better solution, or get your supplier a 2nd vpn connection to the cloud.
You might be able to make this work with a client vpn, or
a summarized address spanning both sites might work, but that would not be supported on the rv042g
Dan
Also, you’ll want to be sure
Also, you’ll want to be sure to secure your VPN authentication beyond just a password using a shared secret between your VPN client and the server. There is a 3rd party integration that will do that.
144
