RV 120W port forwarding range
andrejko55
I am not a tech guy but have to take care of some basic IT stuff. I had Etherfast cable/dsl router and it got changed with RV 120W router. there were comment that internet is now working slowly - what could be the reason for this?
I copied most of settings. First big technical problem was with phone. It stoped working - call could get through but when answered there was no sound. We use linksys modem for VoIP. I called opreater and was told to disable sip alg. I did that and service improved a little. When answering a call sound could get through but would stop for few moments and then continue. Operater told me to forward port 16384 to 16482 to VoIP modem IP.
But I can only set forwarding for one port at the time in "Port forwarding" settings. Is there a way to forward to port range?
2 Accepted Solutions
linksysinfo
Level 4
Level 4
port forwarding has known issues in the RV220W and is recommended you use the firewall access rules instead.  try this on your RV120W
you should also be able to setup a Custom Services to allow port ranges.
Regards Simon
as an example the custom services. (Torrents)
goto firewall, access control. custom services.
Add, then name it
Torrents_TCP
Select: TCP
Start port: 6881
Finish Port: 6889
then save.
you have now added a Custom Service that includes a port range for a Service/Protocol
Okay?
Regards Simon
linksysinfo
Level 4
Level 4
Regards Simon
I tried that (read it in some other discusion), but there was also problem of forwarding only to one port. Or I didn't know how to do it correctly.
About Custom Service; can you be more specific, since I don't know what this is and what to do about it?
Add, then name it
Torrents_TCP
Select: TCP
Start port: 6881
Finish Port: 6889
then save.
Okay?
Regards Simon
I did that. thanks.
But now I don't know.. should't I forward this range of porst to my VoIP modem IP? Custom service doesn't offer this option.
