RV 320 / 325 Dual WAN question
I have a switch that I have configured with a voice vlan. I would like to use WAN 1 as the primary for voice and have other network traffic use WAN 2 for its primary and have both sets of traffic failover if either connection goes down. It this even possible with these two routers. It seems from the documentation that I can do one or the other but not both...
1 REPLY
when load balancing and a wan fails its traffic will go across the only available wan left. so you can set up policy based routing to wan 1 for a specific protocol, and when that wan fails its traffic will flow through wan 2.
326
