Community Member
RV 320 and Huawei E392u-12
Hello Comunity,
maybe someone can help with my problem:
My Hardware:
- cisco RV320 with Firmware 1.1.1.06
- Huwaei E392u-12 USB Dongle
When I conect the dongle to the router, the lights are flashing shortly an then happens nothing. The message in the Router Configuration Menu is "No moden available".
Before i tried the E392, a Huawei E173 was conected and worked without problems (plug in, setup,  Internet OK)
The E392 ist working because i tested it with the USb on a Notebook. The Router ist also OK.
In the release notes for Firmware 1.1.1.06 i read that the E392 is supported
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/release_notes/rv32x_relnote_v1-1-1-06.pdf
And in the Dongle Modem List for the RV320 it is also listed:
https://supportforums.cisco.com/docs/DOC-35515
Has anybody a solution for this problem? many Thanks
Peter
179
