12-04-2013 06:40 PM
I have two Cisco WAP321 AP's and a Cisco RV016 Router.
I use the RV016 as the DHCP server for the network.
I would like to use the guest SSID mapped to a VLAN to issolate it from the rest of the network.
How do I setup the RV016 to route traffic from both the guest VLAN and the internal VLAN to the internet while still using it as a DHCP server.
Thanks for any assistance.
John McArthur
Solved! Go to Solution.
03-16-2014 01:49 PM
Hi, this is basically an unsupported configuration. The RV016 supports only port based VLAN and only 1 DHCP scope. If you want a guest VLAN inconjunction with the router something like a layer 3 switch would need to be implemented between the router and AP to accomadate this configuration.
03-12-2014 03:12 PM
03-16-2014 01:49 PM
