Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
RV016 Bandwidth Management and VOIP Quality Issues
I replaced an old router with a Linksys RV016 at a small office comprising about 15 computers and 15 VOIP Phones (using G729a requiring ~80kbps). I am hearing complaints about the following
1) Incoming VOIP Quality is bad, Outgoing is fine.
2) Downloads to computers are slower than before.
I am a bit new to VOIP but have some solid networking experience. However I am concerned I do not fully understand the bandwidth management of this device and I think the Linksys documentation is a little light.
Should I be using priority instead of rate control?
Are the MIN/MAX rate control figures shared among the IP addresses or are they applied to each? I have adjusted these rates up and down without any improvement (although I haven't been back to test myself).
Below are the settings for the router. If anyone has any suggestions I would appreciate the input.
ISP Speed: 3 M Up/Dn
Router: Linksys RV016
F/W: 3.0.0.19-tm
WAN1: 10M Full (per ISP Modem)
DHCP Enabled: .150-199 (for Computers)
DHCP Resrved: .101-149 (for VOIP Devices)
Bandwidth Management: Rate Control
Service~IPs~Dir~Min/Max
All TCP/UDP Traffic~192.168.1.101-149~UP~256/512
All TCP/UDP Traffic~192.168.1.101-149~DN~256/512
(Also used min max of 1024, 1548)
Firewall Enabled:
Service~Type~Ports
VOIP1~UDP~5060- 5090 (As per VOIP provider)
VOIP2~UDP~16384-16482 (As per VOIP provider)
Rule
Service~Interface~Source~Dest
VOIP1~LAN~.101-.149~ANY
VOIP2~LAN~.101-.149~ANY
VOIP1~WAN~ANY~.101-.149
VOIP2~WAN~ANY~.101-.149
VPN: PPTP Server
(only used by me for adjusting configuration remotely)
Re: RV016 Bandwidth Management and VOIP Quality Issues
i myself am having issues with an RV082. V2 running 2.0.0.19-tm (only new firmware)
the bad call quality is packets droping from your voip trunk.
i have yet to find a way to get the bandwidth rate control to work on
incoming data. uploads are limited just fine. as for the is this
a group limit or a single client limit level i  have assumed that it is a
per ip limit which does not help bottlenecking of the wan connection.
Hi Justin,
Do you happen to have SPI (Stateful Packet Inspection) Enabled on the Firewall?
Thanks!
Dave
David L. Barrett, Jr.
957
