Hey,
We have two Cisco RV016 routers set up and both of them are sitting behind routers of our ISPs. However, on both the routers (provided by the ISP) the DMZ mode is set to the Cisco Routers, so they both have ISP provided public IPs . We managed to set up a gateway to gateway vpn connection but the individual hosts on local and remote LANs can ping the routers respectively but can not ping the hosts on the remote LAN.
Both networks are on seperate subnets.
1 - 192.168.3.0 / 255.255.255.0
2 - 10.0.0.0 / 255.255.255.0
Router A - 192.168.3.0 has the following settings:
WAN1 | WAN2 | DMZ |
IP Address : | 109.x.245.5 | IP Address : | 0.0.0.0 | IP Address : | 0.0.0.0 |
Default Gateway : | 109.x.245.6 | Default Gateway : | 0.0.0.0 |
DNS : | 192.168.3.1 | DNS : | 0.0.0.0 |
Dynamic DNS : | Disabled | Dynamic DNS : | Disabled |
The ipv4 Routing Table is as follows:
Destination IP | Subnet Mask | Default Gateway | Hop Count | Interface |
109.x.245.4 | 255.255.255.252 | * | 0 | eth1 |
10.0.0.0 | 255.255.255.0 | 109.x.245.6 | 35 | eth |
192.168.3.0 | 255.255.255.0 | * | 0 | eth1 |
default | 0.0.0.0 | 109.x.245.6 | 40 | eth0 |
| eth1 |
Router B - 10.0.0.0 has the following settings:
192.168.3.0 | 255.255.255.0 | 82.x.188.1 | 35 | eth1 |
10.0.0.0 | 255.255.255.0 | * | 0 | eth0 |
82.x.188.0 | 255.255.252.0 | * | 0 | eth1 |
default | 0.0.0.0 | 82.x.188.1 | 40 | eth |
Thanks in advance for your help.
