RV042 Bandwidth problem
we use the RV042 as gateway with a 50Mbit glasfiber connection but get only 20Mbit up and 20Mbit down.
If i connect my PC directly to the internet i get full bandwidth up and down.
I tried all settings but no chance.
BR,
Roman
1 REPLY
Re: RV042 Bandwidth problem
Have you tried setting the MTU to manual and adjusting the MTU? I would try this and see if you see a difference. Also
I would look at disabling the SPI-Stateful Packet Inspection under the Firewall tab.
THANKS
290
