RV042 Broadcast Issue
woland_ca
I need some help with RV042 router to allow broadcast to pass through.
I have tried simple scenario. Router is in "Router" mode. Firewall is disabled. Multicast pass through is enabled.
DHCP server in router is disabled. All IP addresses are configured manyally as static.
PC1(192.168.3.10) connected to WAN(192.168.3.20) of router and PC2(192.168.4.10) connected to LAN1(192.168.4.1) of router.
When i trying to ping then both computers are seeing each other. Traceroute also shows 2 hops in both direction.
But when i start Broadcast listener in one computer (for example in PC2 on port 50000) and then send some data to same port and lan-broadcast address(192.168.4.255:50000) from second computer(PC1) then PC2 received nothng . I have tried the same in opposite direction, but it doesn't work either.
Any suggestion?
Thanks.
woland_ca
bump
