RV042 can't stabilish VPN tunnel connection
I have two Linksys RV042, each one on different places. They were working very well till I upgraded both to the last firmware.
After the upgrade, I can't stabilish VPN tunnel connection between them with the same configuration that was working before. When I see the logs of both routers, no error message appears.
What could it be? I try to stabilish connection on both WAN ports. I have two different internet connections on each side, cable and adsl, and the VPN doesn't connect on anyone.
The Firmware that I'm using is 1.3.12.19-tm.
Everyone's tags (3)
Re: RV042 can't stabilish VPN tunnel connection
Good Afternoon,
Have you tried factory resetting the units and then setting them back up?
Hey David,
Thank you! I didn't think about this option.
I did the reset and the VPN is working now!
1935
