RV042 Cisco RoundRobin ?? internet slow speed
System
RoundRobin RV042 Cisco
Youtube.com , facebook, Google,  or HTTPS web
internet low speed
ECMP Loadbalance not working
Fix new firmware plz...
Youtube slow ...
Gold
bunyawat,
Use the Protocol Binding feature to bind HTTP and HTTPS traffic to one WAN port only. Load Balancing HTTPS especially causes problems.
How much bandwidth do you have on each WAN connection?
Do you have two different ISPs?
- Marty
Re: RV042 Cisco RoundRobin ?? internet slow speed
youtube.com config Protocol Binding not working
Load balance Mode
Nvidia.com < Slow
imdb.com < Slow
Download.com < Slow
Youtube.com < Slow
Backup mode
Nvidia.com < Fast
imdb.com
Download.com < Fast
Youtube.com < Fast
WAN1
internet leased line 7/7 Mbps
WAN2
ADSL 2+ 10/512 Mbps
Gold
bunyawat,
Load Balancing works only for outbound traffic, so balancing a 7Mbps connection with a 512Kbps connection is not helping you. Balancing two 7Mbps connections would make sense, but when you are utilizing such a slow connection on WAN 2 you would be better off using the Fail Over mode instead. That way your connections will be fast on the 7Mbps connection and if it fails all devices will switch to the slower connection.
- Marty
Bronze
This doesn't make any sense.  I thought connections were balanced in both directions unless they were bound to a particular wan?
Have you entered in the amount of bandwidth for each WAN?  If you don't do this, the balance algorithm won't balance the loads properly, overloading the smaller bandwidth and not utilizing the larger bandwidth.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
301
