rv042 dhcp screen is blank
RV042 V4.2.2.08.  I'm trying to reserve addresses for our small network but when I try to access the DHCP page, the screen is blank.  I backed up the configuration, then factory defaulted the router and loaded my config and still have the same issue.  Any help would be greatly appreciated.
1 REPLY
Well the only main problem
Well the only main problem which can been seen in this model is the firmware.
Check the follwoing
First change your screen resolution to some thing else and then access/refresh the DHCP page.
Second update your firmware to latest ,if in case it is latest then refresh it again.
Hope this will help.
NOTE: check the config guide and do manual config without restore to test also.
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=4250
42
