Community Member
RV042 : forward a port to a specific WAN
I have a RV042 router with load balancing on 2 ISP connections.
My newsgroups provider does not allow 2 different IPs to connect a single account. So, I bought a second account (with a separate port: the first is 119 and the second is 563).
My question is: how can I route port 119 trafic one the first WAN and port 563 traffic on the second WAN ? If I leave it that way, the router connects to any account with any IP, which my newsgroup provider does not allow.
Thank you
1 REPLY
Silver
Adrien,
I'm thinking you'll need to setup protocol binding for each wan address from specific source address, but i'm not clear on information you provided above.
please call into support center @ 1-866-606-1866 and open a support case. We will need to get a better understanding on what you are trying to accomplish and then go from there.
Jasbryan
755
