Community Member
RV042 - forward to different port
Is it possible to forward complete traffic to, say, 77.88.99.100:1080 to 192.168.1.50:80 in my local network. I can forward port 1080 to 192.168.1.50, but it forwards to port 1080, and I would like to forward to port 80
The ruter is Linksys RV042.
Re: RV042 - forward to different port
The Setup>UPnP page allows you to configure such forwarding rule. Note that UPnP does not need to be enabled to use this feature.
Community Member
Thank you, but it still does not work. Here is the configuration.
When I go to 192.168.1.50 (from my local network) I have access to my Web camera.
In UPNP section I defined service CAM1 (TCP150->80), added it to the list, enabled it and saved the configuration
In Forwarding section I defined CAM1F service forwarding TCP150 to 192.168.1.50, enabled it and saved the configuration.
Pointing browser to 77.xx.xx.xx:150 (77.xx.etc being my static IP address) does not work. However, when I reconfigure Web camera to use port 150 (which is inconvinient for me because recording software I use insists on port 80) 77.xx.xx.xx:150, which means that UPNP configuration didn't change anything.
Please help.
Community Member
It works! I just had to disable port forwarding and use only UPnP. Great. Thanks a lot!
Yes, when there are conflicting rules in Forwarding and UPnP Forwarding, the former rule take precedence. Glad to know you made it work.
3184
