RV042 hacked
my rv042
Serial Number :           NKS15520572
Firmware Version :           v4.2.2.08 (Apr 26 2013 19:12:26)
PID VID :           RV042 V03
no vpn tunnels
no ttpt
ports open 80, 5000. 21
problem :
router is working  for 1 year   no problem.
now i have found some strange  records in the logfile when this packets show up at the router log the router can not be accessed any more by the log on screen. you can enter user name and password  the router is not sending any thing else after  enter user name and password.
the internet connection on the lan side has no problems
if there is a vpn tunel gateway to gateway  the tunnel will drop.
the firewall is still working
but the router is not managable anymore.
after a power  off/on
i'm able to log on.  the router was for 1 year on port 8080 https.
now i changed the remote port to 8888  and no more hangup.
vpn tunnels working days.
i switch back to remote managin port 8080  after 1 hour or so  i start getting the strange packets  and the router hang up.
change port 8888 no hangup.
so  i'm sure there is a way that you can kill the rv042  and may be use a different way
the logfile  after a power off/on is blank.
it look like it is not related to the firmware version as i updated it. what did not solve the problem.
how to solve it ?
Green
RV042 hacked
Hi Rainer, if you'd like, you can set up an external syslog to log events from the router without losing access to them. That may shed some light on your problem.
If you feel you're being hacked or exploited in such a manner, you may want to consider contacting your ISP. If someone knows your external IP and your remote management port, you are the person who allows that connection since you configured it on the router.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
RV042 hacked
Hi tom watts
i'm in contact with the isp, we blocked some ports before to stop a other  flooding.
but since i changed the port from 8080to 8888 the router is back to normal.
the vpn gateway to gateway's  working.
it is a clear sign that it is possible to just send some strange packets and the router hang up on the logon screen.
i'm worry as  we can not see what else the hacker can do see or make.
what i can make is ask the isp to setup a log for the fix ip and put back the router to the 8080 port.
lets see if the isp can provide me with the log
986
