RV042 not sending ProxyID to juniper
I have a RV042 created a gateway-gateway vpn.  I can negotiate phase 1 and when I get to phase 2.  It fails with the following error.
Rejected an IKE packet on ethernet0/8 from ... because The peer did not send a proxy ID.
I'm way over my head on this, so any help would be appreciated.
Thanks In Advance.
Bronze
Hello Joe,
Thanks for posting in Support Forums. Try disabling NAT-Transversal. Let me know if it didn't work.
Vijay
Thanks for the response, I have disabled NAT-Transerversal in "advanced options" in the VPN setup.  Still same error.
Any one?
Hello Joe:
Please refer this article for the creation of the Gateway to gateway tunnel.
Configure Remote Gateway VPN tunnel with a Static IP Address on RV016, RV042, RV042G, and RV082 VPN Routers
Remember that the configuration must be the same in the the 2 points.
I hope this help you.
366
