RV042 opens ports 80 and 443 when HTTPS enabled in firewall
I recently installed an RV042 v1.1 vpn router (older hardware revision but using the latest available firmware 1.3.12.19-tm) and set up VPN access with the QuickVPN client.  QuickVPN requires that the HTTPS setting be enabled under the Firewall options, so I did.  I then scanned our static IP with grc.com's ShieldsUP! to check for open or non-stealthed ports and discovered that ports 80 and 443 show as wide open, while port 113 is closed but not stealthed.  If I disable the HTTPS setting under Firewall, then ports 80 and 443 become stealthed.  Is there any way to use QuickVPN and keep these ports stealthed?
Thank you!
Tim
1 REPLY
Solved this by forwarding ports 80, 113 and 443 to an unused internal IP address.  Tested QuickVPN after doing this and am still able to log on AND have a full stealth rating from ShieldsUP!
1092
