RV042 port forwarding issue
I have a RV042 using (for now), just the single WAN interface. I am trying to forward all packets to port 9000 from the WAN to a single IP address on the network.  I've set up both forwarding rules under Setup -> Forwarding and under the Firewall -> Access Rules.
I cannot connect to my device from the outside world, however.  Is there something I'm missing?
Everyone's tags (2)
Scott,
Can you please let me know if you are able to access the device via the local Lan IP Address with the required port number? Also, can you please let me know what firmware version you are running on the device?
Blake Mereby
I can connect locally no problems at all
Firmware Version: v4.0.2.08-tm
FIxed.
Problem was upstream. Router above was set to put the RV04 in the DMZ, but the config didn't stick. Re configured that router and now it works...
Thanks.
Thank you for the update.
Blake Mereby
1709
