RV042 QuickVPN software Problema
I have a problem with QuickVPN programm,  a can install it and run it.
But when i try to connect to router there come "info" popup : "The remote gateway is not responding. Do you want to wait?"
if i puch no it will disconnect,
if i puch Yes it just wait and ask it again( nothing happen)...
The workstation i try is Windows 7 Pro 64bit
i have only Win firewall on it and its on (IPSec is on ).
I have right sertificate and right password
I have another win 7 workstation with same program wher its working well
The only differens is that it is 32bit version...
My RV042 Router have latest firmware (1.3.13.02-tm) and latest QuickVPN Client version (1.4.2.1)
Can you help me with that? Thans in advance!
Sergei Beliaev
1 REPLY
Do you have any security software running on the 64-bit Win7 computer that could potentially disable QuickVPN Client, which makes use of several .exe programs. You might want to call the Support Center to get more help.
756
