rv042 quickvpn
I've one RV042. I've configured VPN PPTP and it work (I've redirect port 1723 on router1 to rv042).
If I can try to use quickVpn, client login and receive error "remote gateway is not responding". I have redirect port 60443 from router1 to rv042.
Connection it's this: INTERNET-router1-RV042
Can you help me?
Thank's
rv042 quickvpn
You would also need to forward UDP ports 500 and 4500 from router1 to RV042, and enable IPsec passthrough on router1. What router are you using for router1?
rv042 quickvpn
I've forward port 500 and 4500.
Router1 it's of my ISP, I don't know what router.
Client it's windows xp. In router I see which client it's connected but in client log I see this:
2012/03/12 19:45:49 [STATUS]Connecting to remote gateway with IP address: XXXXX
2012/03/12 19:45:52 [WARNING]Server's certificate doesn't exist on your local computer.
2012/03/12 19:45:57 [STATUS]Remote gateway was reached by https ...
2012/03/12 19:45:57 [STATUS]Provisioning...
2012/03/12 19:46:07 [STATUS]Success to connect.
2012/03/12 19:46:07 [STATUS]Tunnel is configured. Ping test is about to start.
2012/03/12 19:46:07 [STATUS]Verifying Network...
2012/03/12 19:46:11 [WARNING]Failed to ping remote VPN Router!
2012/03/12 19:46:12 [WARNING]Failed to ping remote VPN Router!
2012/03/12 19:46:13 [WARNING]Failed to ping remote VPN Router!
2012/03/12 19:46:14 [WARNING]Failed to ping remote VPN Router!
2012/03/12 19:46:15 [WARNING]Failed to ping remote VPN Router!
2012/03/12 19:46:25 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/03/12 19:46:44 [STATUS]Disconnecting...
2012/03/12 19:46:59 [STATUS]Success to disconnect.
Silver
rv042 quickvpn
Marco,
This most likely is a problem on your PC since your getting a remote gateway not responding. This could be related to a number of things. Firewall, anti-virus or 3rd party program causing the Qvpn issue good thing is it's not related to the router itself rather the pc. Here is another post better explaining Qvpn utility.
POST
Jasbryan
895
