RV042 VPN Issue
I have a customer who has multiple subnets.  a 192.x and a 172.x on the RV042.  The primary (dhcp) subnet is the 192.x subnet.  I would like to setup VPN into the RV042 for clients, but give them a 172 address when connecting.  Is there any way to make this happen, or is this just a limitation with only able to give out one range for dhcp?
Thanks!
1 REPLY
RV042 VPN Issue
Frank,
The short is no you can not create this configuration on the RV042. With VPN connections such as Quickvpn a client is not assigned an IP address upon connecting. With PPtP and SSL vpn users are given an IP address from a predetermined DHCP pool, but it can not be within the range of any of the IP interfaces on the router. There may be a workaround to allow remote clients access to your other VLAN, however. What exactly are you trying to setup?
Blake Wright
Cisco SBSC Network Engineer
447
