RV042 VPN Problem
Using Linksys QuickVPN I get Error "The remote gateway is not responding. Do you want to wait?"
Router: Linksys RV042
Firmware: 1.3.12
network setup
Netgear ADSL Router
Wan: XXXXXX our public IP
LAN: 192.168.8.2/27
VPN pass through enable for all VPN protocols, request forwarded to 192.168.8.3
Linksys VPN
Wan: 192.168.8.3
LAN: 192.168.0.2
Client PC IP: 192.168.20.10
When I check the Linksys during the connection attempt: it shows I am connected, you I am getting the error message. when I click don't wait, it will disconnect me.
I tried to disable firewall on PC and on the Linksys, still same result, try to enable PPTP server, still no luck.
sadr
364
