RV042G dual wan problem
tk lam
I have a RV042G and using 2 differnet internet provider
Here is the question, is there any way to setup like some of the service are using WAN1 and some service are using WAN2
thanks
V K Moorthy
yes, you can do that using protocol binding under system mangement---->Dual wan menu.
Note:Configure router in Load balance mode under system mangament.
More info:check the admin guide:
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv0xx/administration/guide/rv0xx_AG_78-19576.pdf
regards
Moorthy
Hi, I did try to set in Bandwidth Management
Type: priority
Interface WAN1
Direction: Upstream
Prority: High
Enable
but when I select load balance the IP will change it to WAN2 ext IP, and this service seem like not working, but I changed it to use WAN1 as the main, its work again
so, i can not use load balance... and i only can use WAN1 to let the service work...
