Community Member
RV042G dual wan problem
I have a RV042G and using 2 differnet internet provider
Here is the question, is there any way to setup like some of the service are using WAN1 and some service are using WAN2
thanks
Bronze
Hi, yes, you can do that
yes, you can do that using protocol binding under system mangement---->Dual wan menu.
Note:Configure router in Load balance mode under system mangament.
More info:check the admin guide:
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv0xx/administration/guide/rv0xx_AG_78-19576.pdf
regards
Moorthy
Community Member
Hi, I did try to set in
Hi, I did try to set in Bandwidth Management
Type: priority
Interface WAN1
Direction: Upstream
Prority: High
Enable
but when I select load balance the IP will change it to WAN2 ext IP, and this service seem like not working, but I changed it to use WAN1 as the main, its work again
so, i can not use load balance... and i only can use WAN1 to let the service work...
97
