RV042G log issues
I think that there is some problem with the logging service. I am using the latest 4.2.3.03 firmware.
I set up Client N to use S/SMTP and S/IMAP on ports 465 and 993 respectively. These ports are forwarded to 192.168.0.211.
I set up Server R to use HTTPS on port 443. This port is forwarded to 192.168.0.200.
However, for some reason, in the logs, Client N is shown to be connecting to port 25 on 192.168.0.211, when it should be 465 or 993.
Similarly, Server R is shown to be connecting to port 25 on 192.618.0.200, when it should be 443.
However, when I connected Client T to access 192.168.0.211 through port 500 (VPN), the port was recorded in the log correctly.
This appeared to have led the subsequent access by Client N to be recorded as 500, instead of 465 or 993.
Is anyone else facing this issue?
Nov 6 00:26:45 2014ACCESS_RULETCP [Server Z]:41653->192.168.0.211:25 on eth1
Nov 6 02:34:14 2014ACCESS_RULETCP [Server Y]:41653->192.168.0.211:25 on eth1
Nov 6 06:08:17 2014ACCESS_RULETCP [Server X]:48718->192.168.0.211:25 on eth1
Nov 6 08:21:02 2014ACCESS_RULETCP [Client N]:48718->192.168.0.211:25 on eth1
Nov 6 09:22:37 2014ACCESS_RULETCP [Server R]:48718->192.168.0.200:25 on eth1
Nov 6 09:36:32 2014ACCESS_RULETCP [Client N]:48718->192.168.0.211:25 on eth1
Nov 6 10:37:20 2014ACCESS_RULETCP [Server R]:48718->192.168.0.200:25 on eth1
Nov 6 10:38:55 2014ACCESS_RULETCP [Client N]:48718->192.168.0.211:25 on eth1
Nov 6 10:58:49 2014ACCESS_RULETCP [Server R]:48718->192.168.0.200:25 on eth1
Nov 6 11:06:34 2014ACCESS_RULETCP [Client N]:48718->192.168.0.211:25 on eth1
Nov 6 11:51:34 2014ACCESS_RULETCP [Server R]:48718->192.168.0.200:25 on eth1
Nov 6 12:04:20 2014ACCESS_RULETCP [Client N]:48718->192.168.0.211:25 on eth1
Nov 6 14:49:16 2014ACCESS_RULEUDP [Client T]:19947->192.168.0.211:500 on eth1
Nov 6 14:51:20 2014ACCESS_RULEUDP [Client N:19947->192.168.0.211:500 on eth1
  • Small Business Routers
30
