07-16-2013 09:06 AM
Hello all,
Can someone pls explain to me the difference between these 2 models? cause i definitely cannot find it anywhere apart from 900mbps vs 800mbps in NAT.
Basically I need the best of them for Dual Gigabit WAN + DHCP to LAN, no need for VPN.
Any idea?
Thank you all!
Solved! Go to Solution.
07-16-2013 09:51 PM
The RV042G is a next generation model of the RV042 while the RV320 is the newer version of this device. Personally I'd go with the RV320 as it will have more support, but also possibly more bugs.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
07-16-2013 09:24 AM
Hey Michiel,
As far as Dual Gigabit WAN + DHCP to LAN goes, I do not believe there is a difference between the devices.
Here are some extra links that may help,
RV320 Data sheet -
RV042G Data sheet -
http://www.cisco.com/en/US/prod/collateral/routers/ps10907/ps9923/ps12262/data_sheet_c78-706724.html
I hope this helps,
Lutz
Cisco Small Business Content Developement Team.
07-16-2013 01:20 PM
Hi Michiel,
The difference between RV042G and RV320 are as follows:
1. IPSec VPN thrpoughput for RV042 is 75Mbps where for RV320 it is 100 Mbps.
2. PPTP VPN connectio for RV042G is 5 where for RV320 it is 10.
And please refer to the data sheet to know more detail.
RV320 Data sheet -
RV042G Data sheet -
Thank you.
07-16-2013 02:09 PM
I think that the link below can be helpful.
http://www.cisco.com/en/US/products/ps9923/prod_models_comparison.html
Michal
07-16-2013 09:51 PM
07-17-2013 01:20 AM
Indeed, i ordered the RV320, thank you very much!
07-17-2013 08:20 AM
Cool! Let us know how it goes.
07-20-2013 02:22 AM
It actually went very well, took me about 10 minutes to set it up with load balancing over WAN (1 fiber, 1 cable) and one to one NAT works like a charm aswell. The only thing I had to disable was the SPI (under firewall) since that slowed down some dns lookups for some strange reason.
07-20-2013 10:39 AM
Sweet! Glad it worked well for you. If you want to leave the SPI enabled, try putting in static DNS entries and see if that helps.
