07-03-2014 11:12 AM
I have a network setup with a hub & spoke configuration using the RV series routers. Due to the fact that bandwidth varies by site and is precious, is there any ports other than UDP 500 that need to be used for allocating the traffic levels?
07-07-2014 06:23 AM
It is not very clear to me what exactly you are trying to configure, maybe you can share more details, but to answer directly to your question - port UDP 500 and UDP 4500 are used by IPSec only to establish the VPN tunnel and renegotiation when the SA lifetime expires. The traffic is transferred by ESP packets.
Kremena
07-08-2014 02:18 PM
Kivanova, Thanks for your input as I was unclear on the data transmission part.
