Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
RV082 and Webex
I'm experiencing 2-3  minutes delays in a Webex session when connected to the  RV082.
If I'm connect  directly to the cable modem everything works fine.
Switching off the firewall on RV082  doesn't help. Are there any other settings which can be changed on RV082 to correct the Webex  latency?
Arek
Everyone's tags (2)
1 REPLY
Silver
Re: RV082 and Webex
Ok, here is something that you can try:
- Go to the firewall settings and disable SPI (Stateful Packet Inspection). This may help improving the speed of the router in general.
684
