We have an older (version 1) RV082 running firmware 1.3.6. After upgrading to firmware 2.0.2.01-tm the web management would not work (page not available). Even though the web management was not working the configured VPNs were working. After resetting the router to factory defaults web management returned, but it stopped working as soon as I restored the router configuration.
I ended up reverting to the older firmware and restoring the router settings.
1) Is there a router setting I should change before upgrading in order to enable web management?
2) In the event I need to replace the router is there a utility that will convert the saved configuration file? I have found mention of a conversion utility but it seems to have disappeared from the Cisco web sites.
