I have two RV082 (hardware version 2, firmware 2.0.2.01-tm) routers at two different sites in town. I am trying to get the gateway to gateway VPN connection to work reliably. After I first connect the tunnel all works well for about 1 minute. I can ping machines on each network from the other network and my tunnel always shows as being connected in the interface on each router. Then, usually after around 1 minute, i am unable to ping from either gateway to the other and vice versa. I used all the default values when setting up the tunnel. I have tried every option I can think of to fix this. Anyone else had or having this problem?
Thanks in advance for any help.
