RV082 hang
I am using RV082 V3 router.
After a reset of the router I have access via both LAN and WAN for some period of time (not yet known)  later that day or the next day when I try to access it via the WAN it sits on "opening page" for a while eventually coming up with the login box. If I close and re-open IE I am unable to connect at all. At this point I also cannot login via the LAN. However, internet access appears to be fully function through the router and the router also responds to pings. (I have the latest firmware loaded.) The only resolve I've found is power cycling the unit to regain login access to it. Very irritating, and impossible when not at the physical location.
Can someone suggest what would be wrong in this
1 REPLY
Bronze
RV082 hang
Hello Siva,
Thank you for using the community forum.
What port are you using for remote management? We will most likely need to see the devices configuration and would need you to call in to the support center at 1(866)-606-1866.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
441
