12-20-2011 01:05 PM
I have a RV082.
I need to set up a VPN form outside to use a Static address from the Lan side of the RV082.
Does anyone know if this is possible?
Lan is 172.16.0.126
Wan is 10.161.48.1
The computer using the VPN will need a virtual IP on the Lan of the RV082 so that it is seen as being on the same network as the equipment on the LAN.
12-20-2011 01:27 PM
RV082 you have to attempt the connection with PPTP. you will need to forward port 1723 internal to wan address of RV082 = 10.161.48.1 from you GW device. You will have to test and see if this will work with your network topology.
Look under vpn tab -->PPTP (enabled) and set range within your range.
Hope this helps,
Jasbryan.
12-22-2011 10:28 AM
I will try that.
I'll let you know if that does what we need.
Rich
