Community Member
rv082 wont start vpn tunnel
Hi everyone!
try to make this short and sweet.
been using the older gray and blue rv082 vpn routers for 5 years with great success.
two died, decided to upgrade them all to the newest version
they are configured exactly the same - new and old
the vpn tunnel will not come up unless I log into the router and click tunnel test.
any ideas?
do not have them infront of me at the moment as i'm in the network and they are elsewhere for testing purposes
but can reply later with any specific set up questions etc.
thanks
m@tt
Everyone's tags (1)
Community Member
working with them from my house today if anyone has any ideas!
Bronze
Hello Matt,
Thank you for using support forum. Please check whether you have the same authentication keys (IKE). Also, try enabling the Keep-Alive settings.
Refer the below article for further details on configuration (assuming that you are setting up Gateway-to-Gateway):
Configuration of Gateway to Gateway VPN on RV016, RV042, RV042G and RV082 VPN Routers
Vijay
402
