RV110W - Can't set a gateway for VLANs
Dear Community,
I'm having problems setting up VLANs on my RV110W Small Business Router. I have updated the firmware to the latest : 1.1.0.9
Here is my set up :
WAN settings :
     IP : 192.168.1.252 / 255.255.255.0 - Gateway 192.168.1.254
VLAN1 (default) :
     IP : 192.168.2.254 / 255.255.255.0
VLAN3 (test) :
     IP : 192.168.16.254 / 255.255.255.0
Inter-VLAN routing option is checked.
Symptoms :
- The communication from VLAN1 to WAN is fine
- The communication from VLAN3 to VLAN1 is fine
- The communication from VLAN1 to VLAN3 is not working
My routing table is :
Routing table Entry List
Destination LAN IPSubnet MaskGatewayInterface
192.168.2.0255.255.255.0192.168.2.254LAN
192.168.1.0255.255.255.0192.168.1.252WAN
192.168.16.0255.255.255.00.0.0.0LAN
0.0.0.00.0.0.0192.168.1.254WAN
As you can see, the gateway for VLAN3 is set to 0.0.0.0, which is wrong I believe. I don't know how to update that. I tried to add a a static route for the subnet, but the router did not let me do that.
How can I fix this problem?
Thanks ahead for anyone who could help me.
Florent
Everyone's tags (1)
1 REPLY
Did you find a solution ? I have the same issue.
976
