RV110W port forwarding
I have new RV110W with firmware 1.1.0.9, which is set to gateway operating mode and I have problem with port forwarding on LAN. I have web server in LAN with services on different ports and static public IP on WAN port and set port forwarding on RV110W firewall in port range forwarding. From Internet everything works fine, but when I try connect to server with public IP,that I have set on WAN port, from LAN, it´s not work. Please can you tell me whether it is a standard feature or I have some errors in configuration or it´s firmware bug? Thanks for your answers.
  • Small Business Routers
1 REPLY
Hi Petr
this feature is called NAT Redirection (possibility to access local resource from local (same) network by external IP address) and is usually disabled by default for security reasons. You can find pretty good explanation here:
http://www.dslreports.com/forum/remark,10449610
Try to add new rule to router´s Firewall // Access Rules.
Abudef
1155
