RV110w wont connect with dsl modem for VPN - HELP!
I have bought a RV110w and also a D-Link 320B modem  (replacing my standard Sky broadband router) and I am having difficulty  setting them up.  The D-Link modem works when connected directly with my  laptop via ethernet but when connected into the WAN port on the RV110w  none of the computers on my network have internet access.  The RV110w  dashboard says that the WAN connection is "UP" and gives an IP  address??  Any help with this would be much appreciated.
After  the above issue has been solved I would then like to use the RV110w VPN  facility which I have been unable to set up correcty using QuickVPN.   The laptop that I want as a VPN client is running Windows 8.
I have been trying to sort this for two weeks with no luck!!!
Matt.
Hi, I am still really struggling with this problem, is there anyone out there who can help me?!?!?!
Matt
Hi Matthew, thank you for using our forum, my name is Luis I am part of the Small business Support community. I apologize for your inconvenience; I have a couple of questions, what firmware are you running? The last firmware is 1.2.0.9 and you could download it here, are the computer connected to the RV110W receiving DHCP?
I want to have this information in order to provide better assistance.
Also I will share an article for QuickVPN, here you will find the configuration for your QuickVPN
https://supportforums.cisco.com/docs/DOC-29399
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
441
