RV120W Pre-Sales Questions
Alfie_Charlie
Hello, I need to connect 2 locations via VPN. May anyone provide pre-sales advice for the Cisco RV 120W Wireless-N VPN Firewall?
1. Is there any "Live-Demo" of the RV 120W?
2. Is there any step by step guide how to establish a VPN-tunnel between two RV 120W devices?
3. What datarate in kbit/s is the router capable of with VPN and QoS enabled?
4. Is it possible to remote flash the firmeware of the router?
5. Is it possible to connect the iPhone to the RV 120W via VPN?
6. Is it possible to use WOL?
Some notes:
1. Yes I have found the PDF manual and you get an impression of the device manager, however, you don't see every single page of the menu, so a Live-Demo would be great. Where can I find a Live-Demo?
2. I found another manual how to connect TheGreenBow IPSec VPN Client to the Cisco RV 120W, but what I am looking for is a guide how to establish a VPN-tunnel between two RV 120W devices. Is there any tutorial?
3. The datasheet says regarding performance: VPN throughput is 25 Mbps. But are there any "real world" numbers with QoS being enabled?
4. There is no specific info in the manual, it just says "In the Router Upgrade screen area, click Browse, locate and select the
downloaded firmware, and click Upload." Can this be done ONLINE via a remote connection?
5. Again I found no specific info regarding how to connect the iPhone via VPN. I found a thread here https://supportforums.cisco.com/thread/2022694?tstart=30 however it refers to another router. I need to know if it is possible to connect the iPhone to the RV 120W via VPN or not. Is there a guide?
6. I want to wake up my NAS behind the router via VPN. Does the RV 120W support the Wake-on-LAN?
Many thanks for your feedback in advance.
7 Replies 7
Alfie_Charlie
Even after 3 days no answers is not what I expected...
Did anyone find a review of the device?
Hi Alfie -- Our Pre-Sales Support Team will be happy to answer your questions. Please visit:https://tools.cisco.com/gdrp/coiga/showsurvey.do?surveyCode=264&keyCode=152072_10 or call 877-604-1494.
Thanks so much for your interest in the Cisco Small Business RV 120W. You'll find additional information here: http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/small_business_routers/index.html.
Stephanie Reaves
Small Business Technology Group
Hello Stephanie,
thanks for your answer. I get an error when following the link:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
I would prefer an answer in written form. Can you provide a working link?
Alfie
Hi Alfie -- The written documentation is available here:
http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/small_business_routers/index.html-tab-Resources .
I do know that the live demo is not yet published but should be available soon.
Please try calling Pre Sales Support at 877-604-1494. They will be able to provide guidance.
Stephanie
Thanks Stephanie, is there a way to get support via email, too? I currently don't have a landline to make calls, only internet. So would be great if there is an option for me, too.
No email support but you can try the online chat support here: https://supportforums.cisco.com/community/netpro/small-business/sbproductwarranty
. In the meantime I'll circulate your question with engineering.
--Stephanie
Hi Alfie -- I received some good information from the Product Manager today. You'll find the online demo here:
http://www.cisco.com/web/sbtg/gui_mockups/RV120W_v10012/home.htm.
Work in progress. WIll be on Partner Central soon.
We cannot give you exact number, this all depend on the environments, but device has build-in h/w crypto engine.
Yes, via WebGUI.
It’s possible, but  not supported or tested.
Need more information. What is the objective?
Hope this helps you.
Stephanie
