RV130 IPv6 /48 and /64 scopes locks up router web interface
I wanted to use the IPv6 DHCP server to hand out addresses for other subnets
It wont let you add scopes that are not part of the Lan IP, So I used a /48
and then used /64 for the scopes
After I saved it, the web interface was no longer accessable
though I could ping the routers IPv4 and IPv6 addresses
I can NOT access the web interface, and had to reset to factory defaults to get it working again
  • Small Business Routers
Everyone's tags (1)
1 REPLY
Hi phibetron,You seems to be
Hi phibetron,
You seems to be doing some tests with RV130 and some of your concerns required verification. I would strongly encourage you to contact Cisco Small Business Support team and open tickets:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
116
