05-23-2012 05:00 AM
Hi NetPro,
does RV180 router support client VPN connections using regular Cisco VPN client?
Datasheet says it works with QuickVPN client. If regular non-Quick client is not supported, can both clients coexist (= be installed simultaneously) on the same PC?
Does QuickVPN client support split tunneling?
Thank you!
Lubomir
Solved! Go to Solution.
05-23-2012 06:14 AM
Hello Lubomir,
The RV180 currently supports QuickVPN and PPTP VPN connections. It does also have IPSec tunnel as well but this does not support the Cisco VPN client.
I have not seen an issue with having Cisco VPN and QuickVPN installed on the same computer.
The QuickVPN client supports split tunneling only.
I hope this answers all of your questions.
05-23-2012 06:14 AM
Hello Lubomir,
05-23-2012 06:21 AM
Thank you, Robert!
L.
